IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5866 Views
  • 14 replies
Hi,I have a working 803 CUCM cluster and 9.03 phone firmwarephones in uk in a UK DTG and are correctly displaying BST timeHave created a new DTG for phones in another timezone applied to new DP etc, but these new phones (7942) only display UTCIf I mo...
Platform CME/CUEI know that by default CUE will direct a call to a mailbox based on the Last Redirected number but can someone explain to me how the following will work.Call into Phone A --> fona to vm --> caller hits zero and is redirected to phone ...
Resolved! CME install in UK
We are working to install a CME system in our UK Company and they told us at first we had ISDN line and then told us we actually had a 4 line multi auxiliary analogue line. We thought that all we needed was a VIC2-4FXO card and we would be good, but ...
ddevecka by Level 1
  • 328 Views
  • 3 replies
Hi,Does any one know if a VG224 using SCCP will register using only single line mode?I have a 3845 and only want VG224 ports to be single line mode to preserve ephone-dn ports and allow IP phones register using dual-line mode. This will maximize feat...
heathrw by Level 4
  • 1159 Views
  • 1 replies
I have a Cisco 2811 that is terminating SIP trunks from my provider. From there I have FXS ports on the router that connect to a PBX. When caller call in and get the voicemail gretting they have the option to press 9 to leave a message. when they pre...
sdwitner1 by Level 1
  • 1443 Views
  • 8 replies
Hello,I need some help to sort out an issue concerning the integration of CUE 8.0 with CUCM 8.0. I have configured the CTI ports and CTI route point in CUCM and all of them are registered.When I issue the command "show ccn status ccm-manager" in CUE,...
cg100668 by Level 1
  • 385 Views
  • 1 replies
