Unable to log into attendant console
I have created a new AC username/password and assigned a phone to the ac user. The problem is when I go to login it says "invalid password, please try again" when I know the password is correct. Ideas?
Hi all,I'm experiencing a problem with CM 7.1.3. When incoming call through FXO port in MGCP gateway is hang up by the caller, status of softphone is still connected. The softphone user hear disconnect tone and i checked the MGCP gateway using show v...
Hi, We are facing problem in our voice gateway.All of a sudden, the incoming and outgoing pstn calls started not working. When I checked the VG,I could observe everything as registered in the VG and CCM. I restarted the VG and showing the pri Lines u...
Hi there,I have 10 ephone-dn's with the same number and I'm trying to make a user-profile that, when logged in, has access to those same DN's. Basically, it's a small call center group and I want to be able to have a certain user in another departm...
Dear AllI have upgraded to cisco callmanager version 8.0(2)i uploaded the license filesevery thing wroking finemy license files are working but when i login to my fist page on cisco callmanager i see this message:the messegae is :Licensing Warnings: ...
I've got a 2800 ISR setup for 8 POTS lines, this is for a remote site opening up soon. The remote site will have 8 POTS lines running into a pair of 4 port FXO's. My question is this; how can I test to see that the lines are hunting properly here in ...
I have an operator - who wishes to listen in on trainee operators. Though you can listen with one of them using the handset and the other using the headset on the same phone - this is not good enough -don`t you love SWB operators!!!!!! On the Nortel...
HiI am having some problem for registrating IP phone with CUCM. My CUCM is connect with Core Switch. My Core Switch is trunked with AccessSW1 and AccessSW1 is trunked with AccessSW2. All the IP phones are connected with AccessSW2.I think I am not p...
We are have installed UCCX 7 and CUCM 6.1 and have installed TAPS as per doc. if we do a debug via the script on either the actual UCCX server or a local machine we get the same error regarding missing TAPS\TAPSCCM.TXT file. The file is on the UCCX s...
HiI want to setup basic Sip trunk with Service provider on my CME. There would be no authentication required for the sip trunk configuration, as per the service provider.In the configuration on CME, do I need to configure the sip-ua OR do i only coni...
Hello,I configure a digital network between two locations unity connection 7, i have 9500 users in the first cluster, and just 90 users arrive to be replicated to the second cluster and the replication is propably stopped.the second cluster don't rep...
Hi All,Just wondering if anyone has had any issues with Arc attendant console client where the directories are not showing on the main page?There is a delay when connecting to the Arc database (from the Client) all firewalls have been disabledany tho...
I have Call Manager Business edition and H323 VoiceGateway 2821 Router. I have configured the E1 controller for incoming and outgoing callsbut I am having a problem with the outgoing calls where incoming calls are working fine without any issues.The ...
Can i have an independent presence deployment to be used for only IM session without the need for any CUCM?Do we have any guides / references for the sameAmbi
I managed two CCM PUB & SUB.One CCM(PUB) occured to fail booting, CCM(SUB) was ok.Now CCM(SUB) is working IPT service.For recover this, I reinstall CCM(PUB).I Backup CCM database & config with Disaster Recovery System from CCM(SUB).And I restore DAT...
Subject | Author | Posted |
02-05-2023 10:01 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
