Is the website being redesign because I can't any VOIP/Call Manager(UCM) downloads?
Hi allCan anyone advise if there is a way to block unwanted calls coming into our gateway. I have done this on a H323 GW using a translation rule and explicit "block this number" . We are running MGCP on this box and using CUCM 6.1.4Any ideas??
Hi Team,Could you please let me what type of reports can be generated if I used B-CAD. Also let me know if I can generate report for Loing & Logout hunt member.Your kind cooperation will be highly appreciated.Regards,Nirmal
Is there any way in call manager through which conference call can be auto disconnected after 15 minutes provided the initiator has dropped from theconference call.
Hi All, I am a newbie on to Voice technology and require your help. My company would like to enable SRST on one of its site and the gateway is configured as h323. Attached is the gateway configuration can someone please help me with the configuration...
NEw 2911Sho ccm - says cucm is downCUCM says fxo ports are registeredI can ping cucm with souce gig0/2 which is voice vlanPhones are not registering either.. I can ping the phones from cucm and I can also open phones in web browserWhat the hell is go...
i have server with unity connection 7 installed on it , i want to connect it with cme router 2911 with call maneger express and i want to activate the auto attendent featur from the unity connection server.
Up until last night we had the corporate directory working just fine. This morning our corporate directory is missing from all of the phones and I can't seem to find the source of the problem. We have to LDAP servers available and they appear to be w...
Hi to all, I have a new UC520, I upgrade CME and CUE to last IOS available, all works fine (voicemail, tranfer, etc), but I want to configure the "Live Record" feature. I follow this guide and it seems easy: http://www.cisco.com/en/US/docs/voice_ip_c...
Is there a setting in UCCX 7.X where I can configure and report on short calls, I need to be ignore ringing calls less then x sec from reports. Caller rings in for x sec and rings off- call can be viewed as abandoned so i wish to ignore any call ring...
All new hardware. Going from CM 4.1 to CM8 and Unity4.1 to Unity 8.The Unity work will all be performed at cutover. Steps:- Extend ADSchema, Exch 2003. Per TAC: I could not run this early because Unity4x in production.- Install Unity 8 on new serv...
Hello, i am looking to have a report or a list with all my phones cluster with the phone load id they used, i want to have this to check if all phones are using the default firmware configured on CUCM correctly because i 've already seen some phones ...
Hello,I'm on CUCM 7.1.5 and I was wondering if there was anyway for a number that is call parked to be accessible from the outside to be picked up. (EX: Cell Phone, or Avaya System Phone).Thank You
Hi,I am installing cucm 7.1.5 on Cisco approved DL380G6 hardware. When I insert DVD and reboot, it goes through hardwaer detection mode and verification for 7845H3 passed. Then it starts installation process. (I think it starts to copy the files and ...
Hi all,Currently I'm running a CUCM 8.0.3.20000-2 in test connected to a SIP Trunk. I'm trying to the Remote Destination feature to work (properly). No I have the following setup:- IP phone A - DN 6204 EPNM 1234566204 (test phone, basic)- IP phone B ...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
| User | Count |
| 4 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
