IP Telephony and Phones
Personalize banner_3
Labels
Resolved! FXO Solution
Hello everybody,I need some help to select a backup solution for PRIs failure in the following environment. We are working with CUCM6 cluster and 2 PRIs, installed in 2 2821 voice gateway each one. I've been told to manage a backup solution through 6...
Resolved! CDR Quick Question
Hi,If someone could confim for me that for outbound calls from CUCM 7.1.3 to the PSTN that a CDR record is only generated when the call is connected & not just when it rings out at the far end.Thanks in advance
Is there any way possible to have a group of devices to be assigned a resource to let a group of people "only" manage specific devices?It would be nice for them to manage only their local equipment and not have the ability to see all phones and gatew...
All,I have the folloinwg configuration for number translation on CME:Can anyone let me know how the translation works? Will it remove any outgoing called number 61? I am a little bit confused on outgoing called and outgoing calling numbers, what is t...
yuhuiyao by Level 4
  • 1038 Views
  • 3 replies
I recently changed my password ccmadministrator of the CUCM. Since in my logs i have the following message  It seems that this Unity tries to log into the administrator account with CUCM. I do not know where to find in unity the process that does.So...
p.pegouret by Community Member
  • 927 Views
  • 1 replies
Hi to all,can a sip 7931 phone monitor sip lines? We are working with cme 7.1 and cannot make it work.I tried with blf speed dials but not work.I think that the 7931 sip phone does not support this feature.Thanks for your help
uosambela by Level 3
  • 816 Views
  • 3 replies
Resolved! disaster recovery
we already have failover configured for both Unity and Call Manager, do i still need to configure disaster recovery? can somone give me scenario fo when i might need to restore unity or cm files? Thanks.Marlon
marasiganm by Community Member
  • 1229 Views
  • 9 replies
Hello All,I am getting ready to do a Unity Connection upgrade from 7.x to 8.x.  Its been awhile since i did a unity connection upgrade.  I recall when i did the switchover from one partition to the other it took about 45 minutes.  If I remember right...
