Hi all,can any body share the procedure or link to configure Call Detail Records on Call Manager Express 7.0 ????Regards,
Hi all - please can I run this past you, I have built a cucm 7.1(3a) server in a lab environment using the version 4.1 tar file to import the devices.As the server I have built is being used in the lab, can I request the Lic file from Cisco and then ...
Is there a way to copy BLF Speed dials from one extension to another? Here is the situation. I have a department that has 10 phones, every one of them want 16+ BLF Speed dial buttons on their phones (they are running 7931 IP Phones's). Most of the...
Hi, The light strip on the handset do not light up even when messages are left in the mailboxes. Version used is CME 7.1 with CUE 7.1. I read that you need to set MWI on to the DN. With CUE 7.0 i have no problem with the below config. The light st...
Hi! How to make 7906G with SIP11.9-0-3S.loads registered on CUCM Express 7.1 provide a busy tone when the other phone drops the call? All I get is silence and I need it to provide a busy tone.Thanks
Hi,I m using cme on cisco 1861. when i configured the router, i have been surprised that it can only accept 12 ephone ( but in the data sheet 15 !!)??this is the show version of the router :####################################show verCisco IOS Softwa...
Hello, We used to be able to ssh into the 79xx phones by setting up a un/pw account for the phone and then using default/user to get into the phone. This seems to no longer work for 69xx or 89xx models. Anyone know if there is a new way to do this?Th...
Hi to all,I have a UC520 with last IOS with CME 7.0 version, try to configure a Nokia E55 as internal device using Nokia CC Cisco, in UC520 I configure aephone like this:!telephony-service load 7970 SCCP70.8-5-3Sephone 11 device-security-mode none ...
Hi,We are trying to get Remote Access IP Sec VPN working on our Nokia E71 to register with our Call Manager. If anyone can guide us in the right direction and whether it is even possible or not will be great. The VPN is terminated on an ISR router (2...
Hi,Is the procedure & patch file required to upgrdae Cisco communication manager bussiness edition (CUCM BE) from ver 7.0 to 7.1 is different from the patch file used to upgrade CUCM 7.0 to CUCM 7.1 ?Can only communication manager be upgraded in CUCM...
Hi All,I have a production Call Manager Express and a demo UC540... I want to highligh some of the SPA500 phones and give them PSTN access. I'm sure its possible, but just thought I'd check here first...Can I tie in my production CME enviroment to ...
Hi all,Could anyone know my problem in voip call as follow ?HK PSTN/local extension---HK PBX---HK VG----HK CE----HK PE----MPLS Network Cloud—US PE---US CE---US VG---US PBX—US PSTN/local extension When customer called to US from HK via voip, the call ...
Hello All, I'am having an issue where when using H323 on a 2851 gateway with CUCM 7.1.2, the calling name does not show up on the phones. Now I have done some research on this and I have configured the following. I read that the h225 command "...
I have several outside sales types that have an interal directory number that simply forwards to a cell phone. That being the case their voicemail lands on their cell phones and they miss the benefits of Unity.If they had desk phones I could setup Mo...
Hello,I am trying to configure an incoming number to be transferred to an auto attandant, AA itself will hv to play different message depending on Time of the Day. One of the options in the AA is to transfer the call back to receptionist and company ...
Subject | Author | Posted |
04-26-2025 05:48 AM | ||
04-24-2025 02:49 PM | ||
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
