Is it possible within MGCP/CM to strip CUID off inbound from the PSTN?
I have uploaded the ring tones to tftp and the Ringlist.xml. Restarted the TFTP Service and have both restarted the device in Call Manager and a hard reboot to the device. The new ringtones are not being displayed as an option. Can some one let me kn...
when joining node 2 to the HA cluster all services activate fine except historical reporting which fails with the following error:Error Activating components.com.cisco.cluster.ClusterException: Component Controller CRS Historical Datastore on node 2 ...
Hello there,I was wondering if there is any way to change the font we see on the screen of a Cisco IP phone, does anybody know about it?Thanks a lot!
Hi,What's the different between publisher and subscriber for Cisco VoiP?
CallManager 7.1(3)SU2 on MCS7835I3CCMService > SNMP >v1v2 > Notification Destination > Add NewSNMP Notification Destination ConfigurationCommunity String <Drop Down> is emptyIn Tools > Control Center - Features Services I’ve restarted Cisco CallMana...
We are planning to install IP-telephony solution based on UCM 8.0 and MCS7816 for about 200 users as pilot zone. In the future we are planning to replace MCS7816 by MCS7845. Are there any way to migrate existing user connect licenses tied to MCS7816 ...
I'm having this issue on outlook where when I receive a VM on my email, double clicking on it it gives me this Microsoft Form restriction:To help prevent malicious code from running, one or more objects in this form were not loaded.I went through wha...
Hi all,I want to know th licensing process for ip phones, and how it would be uploaded in both CUCM and CUCME.I searched a lot, but couldnt find some helpful documents.Pls help
What's different between T1/E1 for Cisco 3800 series?
Hello.We have a CME 7.0(1) with an ephone-hunt configured in this way:ephone-hunt 1 longest-idle pilot 999 list 300, 308, 309, 313, 306, 303, 307, 310 final 399 timeout 8, 8, 8, 8, 8, 8, 8, 8 statistics collect!The problem is that one of the extensio...
i need to upgrade cisco business edition 6.1.1.2000-3 ( cisco unity connection 2.2) to business edition 8.Xi need some help in this topic( guide to upgrade), and if i need to pourchese another Licence , or just i shoud convert the old license.Anoth...
Hi all, I am solving a subsequent problem. I have a H323GW connected to the CUCM 6.1.5. H323 GW has one E1 voice interface.CUCM has three GWs in the route group.If the E1 interface is down, GW returns release message with the release cause 1 (unalloc...
Running UCCX with a Remote Site that has local PRI. Duirng a WAN outage I want to provide some sort of basic queing. So I am wondering if B-ACD is supported with CME-as-SRST? I only see references to SRST not CME-as-SRST, or should I just do some si...
Hi,Our development team have recently rewritten an application to use the webdialer function on the Cisco Unified Communications Server 6.1.2.1000-13. The current setup that we have for the users is that they log in to Cisco IP communicators via Exte...
Subject | Author | Posted |
02-10-2025 04:39 AM | ||
02-07-2025 02:45 AM | ||
02-04-2025 01:17 PM | ||
02-04-2025 06:55 AM | ||
02-04-2025 01:31 AM |
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
