IP Telephony and Phones
Labels
Hi,I have some problem about the CP 7945. When I add the CP 7945 into CM 2821, I cannot select the type for 7945. Is that CME 2821 don't support CP7945 or it need add some config in the CME 2821 ?---------------------------------------------------nsh...
cm6043 by Level 1
  • 710 Views
  • 1 replies
Hi,In our Cisco Unified CM Administration - System version: 7.0.1.11000-2, I have experienced that a 112 call (the Danish counterpart to 911 call in the USA) take a long time (about 15 seconds) before the "0" is inserted in front of the 112 number, a...
Hi experts.I am confused so pls follow my wordings. Lets say, i have a private network and i have SSCP phones every where. Is there ever a need to establish SIP trunk between any routers ?I was just going through cisco gateway/gatekeeper to clear my ...
Jonn cos by Level 4
  • 841 Views
  • 6 replies
Hi, I have a 2801 who use for QSIG with PABX Matra.This router is in H323 not MGCP, and i must configure on this router a lot of dialpeer voip (50).I don't find a document in which i find limitations of number dialpeer for this router.thanks for your...
dlignier by Level 1
  • 571 Views
  • 1 replies
Hello All,We have a Cisco gateway 2800 series with 4 FXO cards filled with POTs lines.  Half of the lines are used for site A and the other half for site B.  I'm researching a way to have the users from Site B go out their POTs lines and same with Si...
