IP Telephony and Phones
Labels
Hi,I have got a cisco 7970 running Sip, working ok in regards to calls via 3cx.One problem the brightness is only half way. I have changed settings to max on the phone but still its in low power mode.Its plugged in with a Cp-pwr-cube3, I was under th...
Resolved! Pause Dial String
I am looking for a way to add a pause in a dial string that is sent from CUCM.  I want to be able to send a call to a number with a menu and have all of the digits for the options in the menu sent with the number. Does anyone know of any wildcards or...
MRCobb by Level 4
  • 1741 Views
  • 3 replies
90 trunks are distributed across three VG's  andthe call flow should be as> follows;>> Call 1 out via vg 1> Call 2 out via vg 2> Call 3 out via vg 3> Call 4 out via vg 1> And so on>> This distribution is acheived by setting up the route group on call...
