IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5539 Views
  • 14 replies
Does anyone have any successful experience with iPhone integration with CUCM.Currently running version 7.If anyone can provide some step by step doc that would be very much appreciated.thx.paul.
pvarenholt by Level 5
  • 7336 Views
  • 23 replies
Hi,I wonder if there are any places where I can see the current number of calls out from our "Cisco Unified CM Administration System version 7.0.1.11000-2" installation and to the rest of the world?By example, if I place a call from my IP-telephone a...
Hi everybodyWe have a problem with the "dial" button. When I dial a number in the phone (7911), the dial button is disabled, I need pick up the handset for that the phone dial the number.I don't understand this situation, I guess this function is bas...
altesan35 by Level 1
  • 712 Views
  • 4 replies
Hello,We are having an intermittent issue of delayed menu conversation response time when attempting to retrieve voicemail.Problem description: subscriber accesses Unity via phone, immediate response for ID/password as well as subscriber name but the...
jasondrisc by Level 1
  • 3875 Views
  • 14 replies
I have a few phones at a site that are pulling IP address from both the VG and from the server. I checked the phones and CM, both show the right address. I did a ping on the odd addresses and they all time out. I have also deleted the address out ...
17roush by Level 1
  • 1831 Views
  • 15 replies
We have all 796x serier SCCP phones registered with CUCM 6.1.4.  From time to time we need to reboot a phone in order to add an extension to the phone.  How can I tell if the phone is in use? On a gateway router I can do "sh voice call active summary...
Am so used to unity never imagined that I would be asking this. Does anyone know howyou install the Lic file to a Cisco Unity Express.I tried theLicense install tftp://192.168.2.20/licfile.licand tried diffrent combinations of the same with no progre...
I have been receiving allott of complaints with the battery life of the 7921 phone batteries.  When first installed 18 months ago, devices could last for a few days wihout charging.  Now the majority of them (70 out of 100, rough estimate) don't last...
I have a customer requesting a dry loop from a VG224. We are using  CUCM 6.1(4). The only port type options available on our VG224 are POTS,  Ground Start and Loop Start, do any of these imply dry loop?Thanx-michael
I have a 7937 hooked up to a CAT3550 and we have PoE runing to that device but it keeps on power cycling. I tried to extend the power on the 3550 by issuing the following command SWITCH#power inline delay shutdown 20 initial 300. All this does is it ...
julienf28 by Level 1
  • 1499 Views
  • 5 replies
