IP Telephony and Phones
Labels
Hi,Can some one suggest for the below error ?MTP Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node ID:CFB Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node IDMOH Reason Code [Optional].:13 Cluster ID:StandAloneCluster Node IDReg...
So I just installed a 7915 and from what my research tells me (CISCO) and all the buttons lit up means I dont have the firmware on the server.Where do I get it and how do I upload it?
admin_2 by Level 3
  • 512 Views
  • 1 replies
Hi,I am facing problem with 4 FXO lines configured on 2811 voice gateway with MGCP/CUCM7. Three lines are working perfectly on voice port 0,1 and 2, but when i connect 4th line on voice port 3 and calls from outside to inside then it gives half ring ...
haseeb by Level 1
  • 1232 Views
  • 7 replies
I have two phones that have people assigned under BLF and when they are on their phone the display does not show that they are. What changes do I need to do to make this work. I have phones that display the user on their phones and are set up identic...
Mojo1 by Level 1
  • 776 Views
  • 7 replies
