IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6105 Views
  • 14 replies
I use Openvox A800P with 5 FXO and 2 spa8000. Sometimes i heared some noise in different telefones. But anoter time they works correctly. How to remove this noise?There are Gateway settings and logs in the attachment.
rezzonans by Level 1
  • 329 Views
  • 1 replies
Hi Folks,               This is the second time that I run into this issue. A weeks back a customer called me at explained that they have a fxs card with 4 ports with 4 analogs phones connected to them.However, they cannot make simultanous calls(two ...
Dear AllWe have a voice gateway  connected via 1 E1 (TDM) with the 20 channel DoD and 10 DiD. We will replace it with SIP triunk (IP based Network) and the customer require the same configuration (20DoD+10 DiD) Is it possible to do that with SIP Trun...
