IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5907 Views
  • 14 replies
Hi everyone,We use a CUCM 7.1.3 with CUBAC as call dispatcher. The calls will be accept and routed with an CTI route point. If the operator wants to transfer the call (cosultand or blind), always the DN of the CTI Route point will be shownon the call...
phartl by Level 1
  • 710 Views
  • 1 replies
Hi,Is there a way to provide CAC bandwidth control of incoming calls on one SIP trunk and to be separated per classification by configuring CCM7 alone?For example:PSTNA ----sip trunk---CCM7----Phone1A                            --Phone2A             ...
jechoi by Level 1
  • 530 Views
  • 3 replies
hi everyone. I am using cucm 6.0 and CIPC. I am also using wireshark to observe the phone registeration process.I read in student guide of CIPT v6.0 that in order to avoid DNS related issues, its always good to specify the IP address in the following...
Hi guys, I Have a CUCM7.1.3 and I have installed the cm-locale-es_CO-7.1.3.1000-1.cop (the latest available) without errors. I have restarted the CUCM and changed the locale configuration of my IP Phones (7911, 7940 and 7960) but with no results, the...
Resolved! USA Calling UK
Hi,I have the following setup on my USA Chicago networkCUCM Publisher 7.1.3.20000-2CUCM Subscriber 7.1.3.20000-2VG2811 (C2800NM-IPVOICEK9-M), Version 12.4(7d)Route Pattern: 9.011!#Calling from Chicago to Australia/Asia/Japan/Middle East via the Inter...
Resolved! ISDN BRI Issue
I am currently testing callmanager 7 with a new service provider switch, however I am having issues with BRI interfaces.I am unable to make a call on an ISDN BRI port under MGCP control (works fine as H323)The debug message on Q931 is*Mar 11 17:33:55...
