IP Telephony and Phones
Labels
External calls are not redirected correctly
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 93 Views
  • 1 replies
CME Phones displaying ITS
their is a problem with only select phones displaying ITS on the display and I forgot what this means. The phone functions fine,receives and places calls, is registered to CME, does not reset... overall it appears to be perfectly normal. The proble...
MMstre by Participant
  • 456 Views
  • 10 replies
Resolved! VIC2-2FXS Fax, fax-relay problem
Hi,Scheme:PSTN Fax -> ISDN BRI -> FXSI have CME 7.1 with VIC2-2FXS on 2801 router. I have tried to configure the port in both ways as sccp controlled and just with pots dial-peer that points to the interface.The most successful test I have achieved w...
Can't get ip2ip to work...
We have some AS5350's which we currently use as a pseudo-ip2ip gateway... calls arrive at one 5350 by IP, are sent by crossover E1 to the other, and then can either go out through IP or through our E1 carriers. I am testing using a softphone and Elas...
chesebrgr by Beginner
  • 752 Views
  • 11 replies
