IP Telephony and Phones
Labels
Hi,I am facing problem with 4 FXO lines configured on 2811 voice gateway with MGCP/CUCM7. Three lines are working perfectly on voice port 0,1 and 2, but when i connect 4th line on voice port 3 and calls from outside to inside then it gives half ring ...
haseeb by Level 1
  • 1483 Views
  • 7 replies
I have two phones that have people assigned under BLF and when they are on their phone the display does not show that they are. What changes do I need to do to make this work. I have phones that display the user on their phones and are set up identic...
Mojo1 by Level 1
  • 945 Views
  • 7 replies
Hello,i have CUCM 6.0 with 2 node cluster on IBM X3650 2CPU Server and company decided to upgrade it to 7.1.i found some part numbers in GPL CM7.0-U-K9-X3650D=SW Upgrade CM 6.0/6.1 to CM7.0 - X3650 2CPUCM7.0-7.1-U-K9=                 SW Upgrade CM 7....
ccna-viva by Level 1
  • 464 Views
  • 1 replies
