Hi all,Could someone share a link or a document on how to configure DHCP server in IOS with option 150 for CUCM ? I am trying to configure DHCP on a 3750 switch for a test environment. Thanks in advance !!!D.
Hi, Need one help. I have CME on 2811 Router. Do I need to purchase License from Cisco for Registering the IP Phones?? I have near about 40 phones.. Rgds, Partha
Set to upgrade from 4.02 to 4.13 this weekend. Checking the caveats a major one is Important: Remove any call forwarding that is set on voice-mail ports that are used only for outbound calls and message waiting indication.Where exactly to I disable ...
Hello,Why are some of my ip phone services not showing on some of my phones, yes i have subscribe the phones to the respective ip phone services, reset the phones several times and nothing, does anybody know why? thanks
Running MPE 2.1.1.2 from a recent upgrade, all is working fine but we just notice that the link to download the outlook Plug-In is not at bottom of the page anymore, after checking Cisco MPE documentation I have verified the following in the administ...
I have a 2801 with a PRI and 2 Fast Ethernet interfaces. We want to dual-home the gateway to separate core switches, with one Fast Ethernet interface to each switch.My question is what is the best way to do this? I was thinking of putting both inte...
hi,In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.any ideas?
Hi all,I have the following issue, I have a CME at site A and an Alcatel PBX at site B. Alcatel phones can call the IP Cisco Phones. The IP Phones cannot call the Alcatel Phones, they get the following error 'Unknown number' and the 'beep beep beep' ...
CUCM 6.1.4when an analog phone is on a call (thru an ATA adapter), and the other party goes on-hook, the call ends, as expected. However, the analog phone gets a second dial tone and a fast busy immediately after the call disconnects.any ideas?
Hi there,I am having real trouble setting up outbound SIP calls from my Call Manager Express!I am using a 2801 running IOS 'c2801-adventerprisek9-mz.124-24.T.bin'. I have around 8 phones running SCCP internally. The Call manager has been working fine...
Hi,I'm struggling to work out when I would need CUBE, and when I would use just gatekeeper.The first scenario is to join 3 CCM Clusters (and upto 5 or 6 later on).Later on we may implement a SIP Trunk to the Telco.At what point do I need CUBE?Thanks.
Hi,I have made an implementation with a lot cisco 7925 and an CUCM 7.1.3The customer wants that the settings access is restriced on every 7925. But they also want that the users are able to configure their own bluetooth Headsets.Is there a posibility...
Hey Guys,I'm getting the below alert in the system logs on our publisher call manager. There is about 10 ever minute. Anybody know what is causing this?Many Thanks Date: Feb 19 08:44:01Machine Name: xxxxx01Severity: InfoProcess: sshd(pam_unix)[17637...
Hi everyone,having a cluster issue and it seems to be indirectly pointing to something with the call manager service.This is the scenario;1. I have multiple locations with Metro WAN connections of 4MB or more.2. We have Four CUCM 6.1.2 servers - 1 pu...
Hi guys, I wonder if you can help me.I have a CM 7 and want to trace a particular set, see what he is dialing, status, etc.I tried to open the "View RealTime" but a lot of messages are flooding the monitor.Is there a way to trace a set and see what i...
Subject | Author | Posted |
01-24-2025 03:51 PM | ||
01-24-2025 03:18 PM | ||
01-22-2025 01:28 PM | ||
01-22-2025 01:04 AM | ||
01-16-2025 02:00 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
