IP Telephony and Phones
Labels
Network topology:[CUCM]    <=> [2811 GW Pri T1]   <=>  [PSTN  / Allstream]            (Site 1)                <=> [1861 GW FXO]      <=>  [PSTN / Allstream]            (Site 2)                <=> [1861 GW FXO]      <=>  [PSTN / Telus]                ...
steve7388 by Level 1
  • 1502 Views
  • 3 replies
Hello Everyone,I currently have a 3745 with VIC-2FXO's (non-battery reversal) and CUCM Business 6 using MGCP.  I need to change the VIC's over to the M1 version, (battery-reversal for North America) to supply Caller ID to the IP phones connected to t...
fieryhail by Level 1
  • 9738 Views
  • 8 replies
I am attempting to upgrade a client to UC 7.  The client is running CM 4 and IPCC 4 on the same box.  When running the DMA tool 7.1.3 it says, "DMA can only be installed on CM or CER Publisher". I would assume its failing because IPCC is installed bu...
joshehaos by Level 1
  • 1409 Views
  • 1 replies
I am looking at a "record all calls" option for ipcc express and just wanted to check that QM has this ability?is there a seperate licence for this option?also does it only work with agent phones or can you use it on non agent phones?can you use QM w...
