IP Telephony and Phones
Labels
Hello Everyone,I currently have a 3745 with VIC-2FXO's (non-battery reversal) and CUCM Business 6 using MGCP.  I need to change the VIC's over to the M1 version, (battery-reversal for North America) to supply Caller ID to the IP phones connected to t...
fieryhail by Level 1
  • 9918 Views
  • 8 replies
I am attempting to upgrade a client to UC 7.  The client is running CM 4 and IPCC 4 on the same box.  When running the DMA tool 7.1.3 it says, "DMA can only be installed on CM or CER Publisher". I would assume its failing because IPCC is installed bu...
joshehaos by Level 1
  • 1468 Views
  • 1 replies
I am looking at a "record all calls" option for ipcc express and just wanted to check that QM has this ability?is there a seperate licence for this option?also does it only work with agent phones or can you use it on non agent phones?can you use QM w...
I have a customer with CUCM 7.1.3 I am trying to find an example "Department Billing Summary" report that can be generated by CDR Analysis and Reporting Tool. Can anyone tell me where I can find this example report?
glenox by Level 1
  • 633 Views
  • 3 replies
Hey folks,I'm having an issue sending out calls from the CCME router. I can't receive calls either though i can hear the line ring when i call it. All phones re registered and have directory numbers assignedFXO configsvoice-port 0/1/0 connection plar...
ndegwajim by Level 1
  • 2748 Views
  • 12 replies
If you have a Cluster over IP WAN config and the link between the two sites goes down , what can be an alternative solution in order for the two sites phoning each other. AAR will not work. Any other views / suggestions ?
jacof by Level 1
  • 1148 Views
  • 2 replies
Hello ExpertsI am new to IP Telephony, can you experts advice on the scenarioToday we got Nortel PBX, management agreed for IP Telephony POCTo start for 40 users, is Cisco Callmanager Express Ideal on Router 2850Can the endpoints be Apple Iphone as w...
melwin.uk by Level 1
  • 748 Views
  • 3 replies
