IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5622 Views
  • 14 replies
Hi, I am trying to configure our cisco router to have any calls that originate from internal extension 37xx to use a certain dial peer and append the digits 1720 in front of any 7 digit number dialed. I opened a tac case and the config below is what ...
Has any one attempted to make the ASA phone-proxy work with CUCME 7? All the examples that I can find refer to full blown call manager and not express.I've gotten the point where a remote phone is downloading a tftp config but rather than trying con...
cklement by Level 1
  • 652 Views
  • 5 replies
Hello,I would like to know if any of you knows what happends to a VG224 when it looses connectivity to a UCM, (this is a vg224 configured as sccp) I know the ports are actually registered with ucm, but is there a way to tell vg 224 to fallback to the...
Anyone know what PSTN technology they use to handle this?  Basically, the client has a direct (no ring) line to the broker office at barclays, jpmorgan, etc.   We assume the client hits a speed dial button that takes an analog off hook which direct c...
Consultation, I have a CUCM 7.1 with a plan to 4-digit numeric. There is a unique three digit number, and when he dials from a VG or ATA, this call takes 15 seconds. This does not happen with the IP Phones.Any suggestions or why is this delay only wi...
Please help on more information on CME cdr records, if i open one of my cdr records that is send via gw-accounting i cannot find the info of the trunk  where the call whent out on, eg. E1 or BRI. Does CME provide your dial-peer or trunk group info fo...
Hi All,Yesterday my CUCM 6.1.3 sub is crashed at 10:16 AM.We reseted it physically at 12:34 PM.I was searching in Linux logs & I found the following lines:Jan 11 12:33:56 KAUSTSUB01 kern 5 kernel: 896MB LOWMEM available.Jan 11 12:33:56 KAUSTSUB01 ker...
