IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6058 Views
  • 14 replies
Hi All, I've setup MTP IOS in CUCM for MGCP T.38 faxing which is required for inbound faxing for Exchange 2007. then create two MRG, one has IOS MTP and the other one has CUCM MTP. then create MRGL that has MRG (with MTP IOS) and MRG (CUCM MRG) respe...
After uploading a Cert for outlook integration, the documentation said to restart the SIP Proxy and Presence Engine Service.... Since then - my SIP proxy won't start....Any ideas.....?admin:utils service start Cisco UP SIP ProxyService Manager is run...
I have 6 FXO ports on a 2821 gateway and I had one of my POTS lines go down. The problem is it was the first one on my trunk groups priority list. It seems that when the line is dead it does not search to the next port in the trunk-group. Is there so...
kgroves42 by Level 3
  • 788 Views
  • 0 replies
Loading the VXML application from the Cisco Unified Communications Manager server (Publisher) to the voice gateway is one of the steps require to configure Mobile Voice Access. My question is; does VXML application exist on the CCM by default or do i...
Hi,I want to config the user with specific rights & privilgesI tried config in Sub user group & tried giving the roles, but then all rights are assigned to these users. But i need these user with limited access for writing & with Read only rights.Cou...
