IP Telephony and Phones
Labels
If you have a H323 GW and only require G729 to be used e.g pign across a WAN do you really need any of the following?voice class codec 2 codec preference 1 g729r8 codec preference 2 g729br8 codec preference 3 g711ulawSince the default per dial-peer i...
iptuser55 by Level 6
  • 1581 Views
  • 1 replies
Hi guys,Im having a problem on CCM 5.1 at the moment with phones and DST. The first generation phones have not updated the DST and are still an hour ahead, whereas the later phones have updated ok. The platform time is correct, as is the date time ...
Hardware: UC520Phones: IP7940Having an issue when transferring a call from one phone to another. Hit transfer, call transfers. No option to talk to the person you are transferring to, then hitting the transfer button.Appreciate any help.Thanks.
Hi, I am wondering the following:If we configure a SIP trunk, and on the providor equipment they specify the trunk IP Address (I assume of the Publisher) what happens in the event of a publisher failure? How will calls be made over the trunk?Can anyo...
mattiep00 by Level 1
  • 1029 Views
  • 5 replies
