IP Telephony and Phones
Labels
I've seen other forum posts regarding this topic but I can't seem to get this to function properly.  I have a customer that uses a dictation company where they call a number, leave a message for what they working on and either hang up or enter a key ...
Hi All, We suspect that one of our user removed all the phones from the PG application user. When I pulled up the audit logs and search by the extension or the PG application name, am not able to find any result.  How can I get to know who disassocia...
ITSP SIP->SIP TRUNK>CUBE>SIP TRUNK>CUCM>SCCP TRUNK>CUC AA I have been having a one-way audio issue when the originating call is from an outbound caller intiates a transfer through the Auto Attendant. I took a look at the debug ccsip messages and see ...
sam saeed by Beginner
  • 31785 Views
  • 19 replies
  • 11 Helpful votes
I wonder if I can enable call waiting facility.Cisco Unified CM AdministrationSystem version: 11.5.1.13901-3What I am meaning is when there is an active call, people can still call the user. They will not get a busy tone when they dial their extensio...
ziqex by Enthusiast
  • 327 Views
  • 1 replies
I have an axis camera connected via third party sip to CUCM, when calling a newer sip phone whenever a DTMF is pressed the call disconnects. Works fine with older model phones, any ideas? if it helps I see this in wireshark before disconnect, BYE rea...
scheived by Participant
  • 221 Views
  • 0 replies
Is there any NON Cisco SIP phone avaliable in the market which compatible with our  existing Network infrastructure using one LAN port to connect desk-phone and desktop PC ? Configuration like in one switch port Switch(config-if)#switchport access v...
