IP Telephony and Phones
watch here Journey banner_1
Labels
Good afternoon, I am in the process of building a CUCM cluster using 2x Cisco UCS C220 M5 Servers (BE6000M build). I booted both servers up yesterday and normally they boot straight to the VMWare ESXI install kernel. Server #01 did but Server #02 did...
I am not satisfied with the way Hunt Pilots with queuing behave in our environment.  We are currently on CUCM 11.5, moving soon to 12.5. I haven't seen anything that looks much changed in 12.5. Expectation 1 - if I turn on queuing, I want the caller ...
Hi Can anyone help. I have been put into a new role that has to get the VoIP phone working in this new company - there is no other communications for them so it is important that they get this up an running. The company has decided to go with 'Gamma...
saunders69 by Level 1
  • 13473 Views
  • 6 replies
HelloI am installed SIP with cnf.xml and xml file and all sip files and upgrade to cisco ip phone, And worked as fineNow i can call from zoiper to cisco ip phone and ring with listen between them,My problem when I need to call from cisco ip phone to ...
loveman by Level 1
  • 1947 Views
  • 6 replies
  • 5 Helpful votes
Hi, I'm facing the following problem: There is a H.323 Cisco voice router with analog FXS ports. When I place a call to the router, it generates the ringback tone and sends it back to the VoIP network (according to "The local DSP will be respoinsible...
AdiHun by Level 1
  • 458 Views
  • 0 replies
