IP Telephony and Phones
Labels
In the configuration guide it states that the mobility softkey when not in a call can be used to disable or enable the mobile connect feature. However, this softkey is not working. All the other things are working fine. The user has to enable/disable...
Hi,we are experiencing call drops, but only from particular numbers (provider). This happens intermittently and only on incoming calls from outside over a SIP trunk.When collecting traffic we can see that Cisco 2811 is sending "200 OK SDP" events tow...
Resolved! SRST / CME
Hi all,I need some advice. we are carrently having a callmanager 6.1 at the head office and we need to have either a call manager express on the DR site or configure SRST at the remote DR site ISR. what will be the best practice? the plan is that sho...
Hi All,We are facing a problem on ports openings between a central site and branch locations.My CUCM and IPCC servers are in location A and my VG is in Location B in between we are using forigate firewall.If all the ports are opened i can able to mak...
