IP Telephony and Phones
watch here Journey banner_1
Labels
Hi Experts,I have a couple of router's in which I install B-ACD. IOS: (C2801-ADVENTERPRISEK9-M), Version 12.4(22)TTelephony-service CONFIG (Version=7.0(1))In one router B-ACD works, in the other one the next message is diplay:*Apr 2 15:58:04.840: //...
abrenes26 by Level 1
  • 586 Views
  • 2 replies
My customer is using UCM 7.1.2 and 2 3845 vgws (1 has local PRI and 2nd gw has LD PRI). Telco won't pass toll-free calls thru LD PRI and customer is using standard route group which is utilizing the 2nd gateway (LD) first then the 1st gw (Local). I c...
mpower78 by Level 1
  • 365 Views
  • 1 replies
To all Cisco gurus,My client currently has Unity 4.0 on 7815 running UM with Domino. They want to upgrade their CallManager to 7.1 but do not want to upgrade their Unity software. Is Unity 4.0 with UM Domino supported to be run with Cisco CallManage...
huntlee by Level 1
  • 337 Views
  • 1 replies
Hi,I have a 2821 with 6 e1 interfaces. From time to time the e1 from the carrier goes faulty. If your call is routed to the faulty e1 you hear fast busy. Is there a way call manager or the mgcp router can detect multiple failures (fast busy) and shut...
HI, I have the following issue:The client has some extensions with number:10X and 100X, If I try to dial to ext 1000 or 1002 instead of ringing 1000 or 1002 the call is routed to extensio 100.The same problems with ext 20X, and 200Xthere is a way to ...
Hi,I just installed Cisco Netmanager two weeks back and I have a problem which I suspect might be related to the hardware. the problem I have is that licensing is done according to the mac addresses.Is there a way to transfer the license to the new m...
