IP Telephony and Phones
watch here Journey banner_2
Labels
Hi all,During a UDP BAT import , I got the following error :"<UDP_NAME> Could not position within a file via an index"How could we interpret this message ?best regards,
tka by Level 1
  • 308 Views
  • 1 replies
Customer has a UC520 trying to separate only 911 calls between two sites. Remote site has a gateway with fxo port. This is the set up I used and when the customer at hartford end calls 911 it goes out the wtby end instead of out the pri. Happens eve...
whanson by Level 2
  • 307 Views
  • 1 replies
Hi allCan you please confirm the correct configuration for a new E1 card install. Currently I have 1 30 channel E1 installed in the 3825 VG. I am assuming all I will have to do is add the controller and timeslots and I should be good to go. Then just...
Hi Guys, Just configured qsig between a 3845 and siemens realitis DX which works fine.. but i just realized that after channel 16 is selected when you try placing another call you'll hear a busy out tone. dubug shows that no channel is available. th...
Hi,I have a CUCM 7.1.2 and a 2811 as H.323 gateway. Say there's a voice-port on the gateway doing connection-plar to extension "1000". What would be the best way of redirecting all incoming calls after 6 pm to another extension?Thanks in advice.Regar...
guilherme by Level 1
  • 483 Views
  • 2 replies
Resolved! Device Pool CUCM
Hi I have a new question about the configuration of the device pool in the Cisco Call Manager.I have the Cisco Call Manager Conference Bridge registered in the CCM. I have two device pool for the phones, DevicePoolSiteA to phonesA and DevicePoolSiteB...
Has anyone worked with this particular solution? I know that it overlaps with SNR in CUCM to a certain degree and with the Black berry MVS solution there are definite similarities however I am particularly interested in the caveats of this solution. ...
skilambi by VIP Alumni
  • 298 Views
  • 0 replies
At the moment the PC port settings in all 400 phones at various sites of this customer are all 100 / Full. They did this for a reason during implementation when they had some odl PCs.Now they have installed new PCs in these 400 sites and the new NICs...
Dear Networkers,We have installed Cisco QM 2.4 SR1 integrated with Cisco IPCCX 5.0(2)Recording is working fine with QM server.I can see and listen to the recordings via QM desktop. I can also save the recordings one by one. for every agent.My issue i...
Top Solution Authors
