IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5760 Views
  • 14 replies
I have been looking at adding MOH, Ring tone and a background image. I noticed that for at least one of these I need to log into the OS admin webpage. However, I was told that my login would not work for this site. What role do I need to be placed in...
Hi all,When I configure SRSRT I understand that it is an exceptional situation and therefore when a phone looses connectivity with CM and falls into SRST mode, it also looses a big part of its configuration. That is, CSS, hunt groups, pickup groups a...
mcibanez by Level 1
  • 1436 Views
  • 4 replies
I have a hunt pilot forwarding to a supervisor phone after 10 seconds of RNA. Problem is that if the Sup isnt sitting at his phone the call doesnt go straight to his voicemail box. It just goes to unity and prompts the caller to enter the mailbox num...
admin_2 by Level 3
  • 717 Views
  • 4 replies
hi,i have many client with cisco call manager express 7.0.1i copy the CME-locale-fr_FR-French-7.0.1.1.tar in flash:its/i execute the commande in telephony-service:user-locale FR load CME-locale-fr_FR-French-7.0.1.1.tar.i created ephone-template with ...
bsaid1977 by Level 1
  • 285 Views
  • 1 replies
Hello,I have a problem on CCM 5.1.2. I can do the administration via web gui but no changes are really applied. E.g. I change DN on the phone, reset the phone everything looks fine on CCM but phone stays with the old DN. I delete the phone , and it i...
HelloI have a little problem with our CM 4.1(3)sr8a, OS 2000.2.7 with Upgrade to 2000.4.5a and OS Service Release 2000.4.5bSR5.I like to monitor the number of registered phones, cpu usage, memory usage etc. with the RTMT.I don't know why, but it does...
Hi There, this issue is causing me much frustration. We are running CUCM 6.1 and a 3845 ISR running advipsvcs 124-15.T8 IOS. Basically, outbound calls are not matching the specific dialpeers that I have configured on the H323 Gateway. We also have...
uccertltd by Level 1
  • 470 Views
  • 2 replies
Dear All,I have implemented CUCM 6.1 with MGCP gateway...just need to clear one thing that is somebody told me that Call ID is not supported with MGCP gateway but it works fine with H.323 gateway...currently i am not able to see calling party number ...
tiger_401 by Level 1
  • 3469 Views
  • 9 replies
