IP Telephony and Phones
watch here Journey banner_1
Labels
Hi,We are using CCM version 5.1.3 which says that CDR are automatically backed up through DRS.There is no need to select CAR/CDR feature to backup this data. IN DRS, we get option of CCM feature only.After the backup is taken successfully, I do not g...
amansoi_5 by Level 1
  • 1309 Views
  • 1 replies
I would use SNR to have my IP Phone and my mobile phone ring simultaneously. Everything is setup and works fine except one thing.If my mobile phone has not taken the call after 20s, it should be connected to the voice mail of the mobile, but the gate...
Hi,Im using CME 4.1(0) and I would like to be able to transfer a call from a phone connected to a VIC-2FXS to another (IP)phone.How do I need to configure the FXS port? Or is this just not possible and do I need to connect the phone to an ATA 186 to ...
Hello,Is there a way that I can send vmail to another vmail. For example, I have a user named John and he receives a vmail but his boss Sam would like to forward John's vmail to his vmail inbox.Is that possible?Thanks in advance
Can somebody please confirm the operation of Power Fail Phones (Red Phoes) on the NM-HDA.Our install would like PSTN Line connected to MGCP Controlled FXO Port to trigger a Hunt Pilot Point.Upon power failure of the Router calls should be sent to an...
iwearing by Level 1
  • 447 Views
  • 1 replies
If I install DMA 7.1 and export the database from CM 4.1 can I restore/migrate on CM 6.1.3 ? OR I can do restore that only in CM 7.x.I could not find anything related to this in release notes for DMA.Thanks for your help.
balukr by Level 2
  • 392 Views
  • 2 replies
