IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5775 Views
  • 14 replies
Hi all, We have a psenario having ccme conncted to remote end PBX through sip trunk.I can make voip calls from here to remote.I need a solution to reroute the calls through pstn automaticaly if this voip line is down.If anyone having solution fo...
Hi Guys,I am trying to get some voice translation rules working for incoming calls for one of my clients. This is for incoming international calls, the telco is stripping the leading 00 therefore only presenting the 44 in the case of incoming calls f...
Good Morning Netpro'ers :)I'm really hoping someone can solve my dilemma. I have a range of phones that when dialing externally i wish them to use the g729r8 codec. I know how to do this on the gateway under the voip DP with the voice class this is n...
My MCS-7825/CUCM 6.1 won't boot - Linux file system error. There is Unified Communications Manager Recovery Software - 6.1.2.1000-13_recovery.iso for CUCM . I can't find any guides how to use this recovery CD. It is possible to restore Linux OS on MC...
olegm by Level 1
  • 607 Views
  • 2 replies
Hi All, I've assign corporate service in all phone in CUCM 7.0. then add SD URL to the second button on the phone. I've copied URL from Enterprise parameters. When I press second button on the phone to see corporate directory, it shows all directory ...
I'm trying to migrate users with the GSM tool. The GSM error with licensing issues. When I go to launch the Licensing tool, I get this:Error querying AvDOM.Error number: 0x80040155Source: avLicDescription: Method '~' of object '~' failedSame error c...
