IP Telephony and Phones
watch here Journey banner_2
Labels
Hi there, Can someone please suggest what is the partnumber for the renewing the license "CUWL-PRO-K9", since this is EoL. Do i need to buy the replacement product itself, or do i have an option to upgrade/migrate. If so what is the partnumber Thanks...
sameeh.pp by Level 1
  • 540 Views
  • 2 replies
Hello All, I'm trying to register my Cisco cube router 3825 with the service provider. My cube is sending the register message with "expires: 0" even after receiving 200 OK. Are the below messages fine? As per the provider, the format is fine for th...
mailgunj by Level 1
  • 4867 Views
  • 11 replies
We have a hunt group for our product support. When everyone is on a call it goes to voicemail and although everything is setup correctly, they never get a voicemail. The voicemail picks up and it allows you to leave a voicemail but when they go to ch...
Hi Everyone, i want to ask about Route list registration:So my company has a h.323 gateway to avaya on one of branch office that has CUCM A sub  (let's say branch A). I've configured a route pattern, a route list, and a route group (which only have t...
We have a setup as follows:We have a Line Group for our Mortgage Loan Originators, and this is set up in a circular pattern in order to rotate calls. The numbers in the Line Group each forward to the MLOs' respective cell phones.We desire to have it ...
jmorton1 by Level 1
  • 630 Views
  • 1 replies
We have two (2) ISR 4321 connected to the ISP via SIP, we are getting disconnect and the only way to fix the issue is to restart the Interface.   We get the following issue.003116: *Aug 10 17:29:03.257: //34363/DFC86B29AAA7/SIP/Error/sipSPIFlushDefer...
Hi All, Need some advice regarding expressway compatibility with CUCM version 10.5. Yes I know the version is old and needs upgrading but the customer is not in a position to do so just now but does require MRA. The matrix says minimum is 8.1, recomm...
We have a set of new 8841 phones that re-register when going off-hook/on-hook.  I've got a TAC case open, however we have not found a cause.  Thought I'd post here to see if anyone as seen this behavior from these phones.  CM is version 10.5 running ...
We are using the 8851 IP Phones and for the speed dials we would like to have a button that does the area code and first 3 digits and then pause to allow the user to enter the last 4 digits.   Is there anyway to do it?I tried # and commas in the spee...
Top Solution Authors
