IP Telephony and Phones
Labels
Hi,We are using CUCM 6.0, the issue is when i receive a call from TDM on my IP Phone and i blind transfer the cal to another IP Phone, PSTN Caller doesn't hear any music while the other IP phone is ringing.PSTN caller hears music if I transfer the ca...
Hi all, I have a problem with my CME and CICP ver. 7.0.1.0I have set in telephony-service some phone url, checked with command "more" if it's present on conf file, checked with debug tftp event if it's the correct file that my CICP download but nothi...
I need to use TAPS for a roll out but unlike 4.x which I`ve used it on before, TAPS is windows and CUCM is not- Has any one used TAP`s in a 6.X rollout and how. Do I need to install a new Cisco Windows server and point the CTI RP to it. On 4.x, I ...
iptuser55 by Level 6
  • 345 Views
  • 3 replies
Dear FriendsI have an issue with my ip phones, i want all the phones (5) to ring when the call lends at the router. can any one please help me with this, the system is working fine just wanna resolved the above issue. There are four 7912 phone and on...
Hi,Is it possible to copy/paste in an excel doc or generate a csv file when you do a search of devices registered in CUCM ?Results of devices registered can't be exploited and impossible to generate a report with such details.Thanks in advance
fgadacha1 by Level 1
  • 375 Views
  • 1 replies
Hy Guys,My Customer have a CallManager version 3.1.3a with 15G of HD and need space avalaible. I delete the files in CDR but the space is short and didn't solve the problem. It's possible delete anothers files thing to have more space in the HD?Thank...
