IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6326 Views
  • 14 replies
Resolved! Router Capacity
Does anyone have a document that shows how many users are typically supported on a 2821/2851 and 3845 voice gateway which will be configured with SRST failover? I am trying to define a baseline for my company as to when we should go from a 2851 to a ...
dvanzee by Level 2
  • 392 Views
  • 1 replies
We are in the process of converting a 2851 mpls router into a voice gateway. I know the 2851 has 3 slots for PVDM's and I figured I needed to put a voice image on it. This router is going to be handling 3 T1 Pri. It will also be an MGCP GW. What else...
dvanzee by Level 2
  • 405 Views
  • 3 replies
Below is the current config of the gateway a client's Call Manager 3.3 is connected to. I have a pending raid failure on the publisher, and want to ensure callers can still dial out and recive calls if the publisher fails completely and it is being ...
