ata fax relay
does an ata support fax relay
I have a problem to insert a new phone 7941 (7961), in CallManager 4.1.3. There occurs some error in scripting during insertion. I can not do it using BAT, too. There are already some "working" phones 7941 in the system. There is no problem with 7911...
Hi,Im currently installing a 6.1 cluster and reworking our route patterns, at the moment we have individual router patterns for each location.I've read that best practice states if you want to filter numbers then don't use the cisco numbering plans a...
Hi all,the cenario is the following:i have my phones in SRST (a 2811 router and i lost connection to CCME), i have a dial-peer pointing to a softswitch for all calls, no problem with that. all calls work fine.my problem resides in manipulating the fo...
Can someone supply a good example of CatOS C2948 config for QoS for voice?I've been unsuccessful at finding a good config guide on CCO.Thanks!
Hi,I have a strange issue since yesterday.I upgraded my CME from 4.2 to 7.0.Someone from PSTN call a DN (20) which have a call forward all to an other DN (30). On the phone I can see on the display the Original Calling Number and Called Number.It's a...
Hi all,I have installed a UC520, it works fine, but if I press DND softkey does not occur nothing.Why? Which could be the problem?thank a lotAugusto.
Hi Guys,I am trying to setup external voicemail access to CUE using one of the PSTN numbers. I have tried different things and currently have a translation rule to match my designated pstn number and replace it with the pilot number. However this is ...
Hi,Can anybody help in trying to trace the following file -cm/trace/dbl/showtechdbstateinfo_cdr_err3829.outCheers,James
Hi,I want to ask about how actually MGCP works in Call Manager. When a gateway is not reachable again by the Call ManagerHow long will it take for the Call Manager to change the status to unregistered ? Because in my site, it still registered until o...
We are running Unity 4.0(3) with Exchnage5.5. Problem is we are unable to access Unity Admin web-page. On the right-hand side of the system tray I saw the message "Unity Stopped" which means that Unity Service has stopped. Tried restarting the servic...
Hi All,I try to do QoS on my routers for VoIP, but i can not overcome traffic congest issue.I only have 256 kbps bandwidth and would like to reserve 128 kbps bandwidth for voice only. Emails or anyother traffic should not touch that bandwidth. Can I ...
Hi All, I am facing problem while registring IP phones on CCM version 6.0 on SIP.But when I am selecting Device Protocol as SCCP, phones get registered .The error which appears while registering on SIP on IP phones ERROR REGISTRATION DBCo .On CUCM Ad...
Hi,We are facing two problems on CCME 7.0 with 2 cards / 2ports FXO.When we call from the Co Trunk line, there is one ring from the CO before the CCME ring starts. And when the call is made from the prepaid mobile phone we notice that the billing sta...
folks could you please tell me the commands that i need to issue in order to upgrade the firmware version on my phones i have 7941s only and they are runing and older version and i cannot get the to download the latest one
Subject | Author | Posted |
02-06-2023 10:54 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
8 | |
4 | |
4 | |
2 |
