IP Telephony and Phones
Labels
Hi,we wanted to add a CME in our CU Operations Manager. We added it with its management IP, but because this IP is different than the IP for managing the Call Manager, it appears as unreachable in the CUOM.Of course, there is a firewall between the C...
Chaps, I have 7 sites, all serviced via a centralised CM 4 cluster. Each site uses a 4 digit translation pattern where I add the full national dial code under the prefix digits section so that all calls are routed out via the local voip gateway over ...
Looking at my Config File (GW 5400), I found:interface Group-Async0 ip unnumbered FastEthernet0/0 encapsulation ppp ip tcp header-compression no ip mroute-cache async mode interactive peer default ip address pool dialin_pool ppp max-bad-auth 2 ppp au...
I have 2 CUPC users. When 1 of them updates the contact list it happens immediately. When the other one does it, they have to logout/login. If I login on a different PC, then problem still happens so appears to follow the CUPC user. I can't see any d...
billybjo1 by Level 3
  • 205 Views
  • 1 replies
