IP Telephony and Phones
Labels
Hi All, I am using CUCM 6.1 and trying to configure Extension Mobility. I did all steps based on Cisco documentation but when I press service button on the phone and choose Extension Mobility, nothing happen and it seems doesn't work. even there is n...
Guysjust to get the basic steps down. we have a CCM 4.0 currently and need to migrate to a 6.1.2. the customer ordered the 6.1 preinstalled server already. can we use the DMA. im seeing that we need to have 4.1 to go to 6.1 so im assuming no. if tha...
a.gooding by Contributor
  • 262 Views
  • 6 replies
Is there a way to tell if calls on my MGCP gateway are inbound or outbound on my T1 PRI ?I was running the following commands, and none gave me an indication. I am sure there is a command for this...sh voice call sumsh voice call statsh call active ...
cplatt01 by Beginner
  • 254 Views
  • 4 replies
We installed a new gateway with a FXS card for fax. Basically i mirrored the config of another router we have configured. Call manager is communicating with the gateway but when i go to "see endpoints" for the gateway, it has "Status: Rejected". Does...
Im doing a new post because I rate the latest post before test the solution you give me.Also Thanks to all people is contributing with comments, but I believe that with the UC500 is a little different, UC500 only support one language at time.Thanks....
