IP Telephony and Phones
Labels
Hi,I want to set up a dial-peer cor list to prevent my directly attached FXS ports from dialling internationally, and to stop my SRST devices calling internationally. I have set up some cor lists etc, but find that during normal running, calls from m...
simmo by Beginner
  • 348 Views
  • 1 replies
Resolved! MRGLs
Hi,I want to know the best way to configure MRG's and MRGLs when I have remote branches, which remote routers/dsp resources.For example, I want a phone in a remote branch to utilise the local dsp resources in the first instance, and only use CCM reso...
simmo by Beginner
  • 231 Views
  • 3 replies
We are running CCM 5.1 with CRS 4.5(1). My vendor has set up a prompt recorder using a route point. The instructions state that I record a particular prompt by dialing the RP (2764 for example) enter the password and then enter an ID (1014 in this ...
Can a CUE Auto-Attendant work without any "Call-in Number" configured?Is there any chance the system might play some default .wav files in the default AA script when all extensions are busy & the call is forwarded to Voice Mail?
