IP Telephony and Phones
Labels
We are coming off of an Avaya Definity G3 switch onto a new UCM 6.1 system. Something those users have come to need and want is a call forward delay. They like the calls to ring x amount of times at their desk before it is forwarded off. I have seen ...
jbingham by Level 1
  • 216 Views
  • 1 replies
Hello,I have a cluster of CCM (1 Subscriber , 1 Publisher).There are in security mode with CTL from two tokens.Unfortunelty, both tokens were locked.We have bought two news token to insert on this cluter.Do I need to use the old locked tokens to upda...
DWAM_2 by Level 3
  • 680 Views
  • 1 replies
Hi,I'm doing SIP trunking with the german voice provider QSC. You can find the config and the version data below. In some points it works fine, but dialing in from somewhere else (e.g. mobile) than from a fixed line of the Deutsche Telekom doesn't wo...
In planning a new deployment, I assume we should go with 6.1? Reading the datasheet, it doesn't appear I "need" any of the new features in 6.1. But I assume it's better to start off with the latest release?Any reason to go with 6.0.x instead?Thanks...
Hi,whenever i try to generate a report User Reports->Top N->By number of calls, i always get a report with only one user. When look through CDR's by extension however, the calls are all there, from all the users.Am i missing something?Regards,Marko
Resolved! SRST Times
HiThe phones unregistered in SRST when the wan link go up the register in CCM is very fast. But the phone registered in SRST when the wan link go up the register in CCM is 60-80 seconds. Are there any way of customize it?
