IP Telephony and Phones
Labels
I have tried this before about 5 months ago and found the same issue. I had hoped that by now Cisco would have fixed this issue.I have a 3825 currently running 12.3(11r)T2 as our voice gateway that has two PRI's terminated into it for PSTN access. ...
Since Cisco have changed the download website, I can no longer find the readme release notes that used to accompany a CallManager patch/SR. All it does is refer you to a link that contains the baselines release notes, which aren't the correct ones. W...
billybjo1 by Level 3
  • 389 Views
  • 1 replies
With CUCM 6.0, can it be configured where for inbound PSTN call, it will have one ringtone, whereas for inbound internal call, it will have another ringtone.Is this possible??
huntlee by Level 1
  • 405 Views
  • 2 replies
