IP Telephony and Phones
Labels
On CallManager 4.x, I am considering creating a publication of the CallDetailRecord table using push replication, so that we can access the CDR data away from the CallManager.Is this a bad idea or is there anything I should look out for.Thanks for an...
Resolved! UC and router 1861
I have the following requirement:IP telephony for 8 user, about 6 agents will be using simultaneously on PSTN network (approximately 5 incoming calls and one outgoing calls using head phones), voice mail optional My solution is:Cisco part no. C1861-...
dshrestha by Level 1
  • 450 Views
  • 1 replies
Hi there,I need a help from you, to have a solution with VoIP and PBXs. So, I want to connect a VoIP machine to a PBX in order to send all the international calls towards this VoIP server. The call scenario should be... analog phone --> PBX --> digit...
Anyone who can inform me , is this dial-peer can used for both MGCP and SRST H323 DID in and SRST H323 out? or I have to split with 3 individial dial-peer,one is for MGCP , another one for SRST H323 DID in , and the last one for SRST H323 out?dial-pe...
I wanna what's Conference Max SESSION here meaning? Does it mean the qty of the conference(not the participant)? If yes, is it the qty under G711 or G729?dspfarm profile 1 conferenceassociate application SCCPmaximum sessions 12And, does MTP and trans...
HI all,We are interested in setting up an IP Telephony to cut down communication cost especially for overseas calls which translate to SGD10,000 every month.Number of users : 110With above requirement kindly assist me on the following:1. to recommend...
jachowda by Level 1
  • 320 Views
  • 1 replies
Hi,I have configured CDR in a CCM 4.1(3) and now try to collect data. When trying to get bill report i have an error message : 30061 : data is not available in the Database.Something missing in my configuration ? i have checked step-by-step each deta...
dom.a by Level 1
  • 610 Views
  • 6 replies
