IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6717 Views
  • 14 replies
Hi all,I found alot of document teach you how to configuration on MCID. But none of the document mentions about the wave files. what do we use it for ?if you are going to test the MCID feature on the IP phone. I believe all you do is pressing the MCI...
trienguy by Level 1
  • 635 Views
  • 4 replies
Hi Guru's Im having a hard time in configuring my ip trunks. My current setup is PBX- Router-PIX-Router-PBX. Im looking for the sample configuration on my router (dial-peer,etc) and PIX 722. Appreciate your help.Thanks,Jong
