HiWe have an issue where call display is not working. Our ISDN-PRI supplier advised that we are using NI2, and should switch to NI1.Is there any problems with doing this? And if not, how do you go about changing it?ThanksRobert
This is a CCM6.0 pub/sub environment with a 2821 connected to a dual T1 multilink connection configured for SIP trunks. Everything has been turned up and seems to be working except that an inbound call on a SIP trunk will be dropped when put on hold...
How can I set up a softphone on a laptop and use only one license, but use it no matter if I am connected wireless or wired with one MAC address.-J
Hello,We have connected a Public Address System to a FXS Network Module (NM-HDA) with the following configuration:voice-port 1/0/Xdisconnect-ackdisc_pi_offcptone EStimeouts call-disconnect 5timeouts wait-release 5Anyway, the port continues busy after...
Hi , I have a customer using CUCMBE - VER 6 and they want to install a 3rd Party CDR Analyst tool (call Ringmaster). They have advised me that the CDR info can be sent to a remote IP address. However they have not told me how this is to be configured...
The Hotel need the billing system for their Cisco Unified Communication system. They currently use CCM 6.x . What software/appliance should I use in conjunction with Cisco CallManager to meet their requirement?Thank in advance
This is more of a "How does this work" question. This is an output from a "show call active voice brief" There is only 1 call active on this gwTelephony call-legs: 0SIP call-legs: 1H323 call-legs: 1Call agent controlled call-legs: 0SCCP call-legs: 2M...
When running individual reports with the detail option I will occasionally get duplicate call records. The records will have the exact details of the call, ie time and date, hhmmss, number dialed ect. If I run a detail report on the gateway the call ...
I have a issue with low volume external calls coming in. The calls are delivered to the company via an ip ip gateway from the service provider(H323 to H323). The ip phones are then located across WAN links at remote sites. Only 2 out of approximately...
Hi Guys,We have various Services set up on our IP phones.. created in Feature - IP Phone services..We now need to remove a particular service from our phones, however I cant seem to find a way of removing it without going into every single phone !!.....
I have a CUCM version 5.0.4.1000-1. Can I use update to a version 5.0.4.4000-1? My update attempt failed when performing "IDS Install". Can anybody help?
Hi all,I have one router which is configured as MGCP and where i have two connections for the PSTN : 1 PRi and Two BRI but i'm asking if i can use the BRI as a bachup i mean the preference 0 would be the E1 and the preference 1 would be the BRI for o...
Hi,I have a Cisco 877 where I wish to have an IP phone behind a NAT gateway and a CM cluster which is Internet accessible and I cannot hear the called party but they can call me. Has anybody done this before and could advise what settings I could us...
Hi Guys,I need to know in the event a Nokia phone becomes usuable how do I de-register the licensing for Nokia Intellisync Call Connect for Cisco on one phone and put it on another. Have searched the Nokia and Cisco Website and have tried googling. S...
hi networkers, i have starnge issue , which is calling international numbers most of the times fails and i got annoucment " your call can not be completed as dial please ..." , . i have configured the phone as follow: device CSS:Internal_only_CSS DN ...
Subject | Author | Posted |
02-17-2025 06:15 AM | ||
02-14-2025 02:33 AM | ||
02-10-2025 04:39 AM | ||
02-07-2025 02:45 AM | ||
02-04-2025 01:17 PM |
User | Count |
4 | |
3 | |
2 | |
1 | |
1 |
