IP Telephony and Phones
Labels
External calls are not redirected correctly
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 72 Views
  • 1 replies
outbound call issue
I am running CCM 4.2. I have a facility that uses a 2820 (h323) for outbound cals through a T1. When calls are placed, the router sees the call but it takes 10 seconds before the call rings out. During this time the IP phone says "call proceed. This ...
ahab by Beginner
  • 309 Views
  • 3 replies
MOH-USB-Audio with 6.1
Does anyone have experience with configuring a single fixed audio source (live stream? The guide is not intuitive enough and currently all users have is silence when placed on hold. The stream is a radio station (company owned). We also cannot tell...
rudyfaber by Beginner
  • 505 Views
  • 9 replies
Can't telnet to 7970G
Hi,We need to telnet to one of the phones to monitor some traffic but we can't telnet to it (192.168.3.53), whenever we try we get the response:C:\>telnet 192.168.3.53Connecting To 192.168.3.53...Could not open connection to the host, on port 23:Conn...
Resolved! CME B-ACD MoH gets choppy
Hi,I am having a problem with B-ACD Moh. What happens....when i call in, i get the CUE-AA (thanks for callinn....press 2 for Customer Service) when i press 2 it goes to the B-ACD hunt group and listed extentions ring 1 after another. if no one picks ...
Translation in CCM
Hello,I planning to have 10 digit extensions in CUCM I want the users to be able to dial both 10 digit or just last 4 digits of their numbers to call each other? How can this be done, since all the translation rules refer to external calling and not ...
VG224 line error on incoming FAX's
FAX's connected to VG224 receive line error on incoming FAX's. Outbouond FAX's complete successfully. This is an MGCP gateway I will include the MGCP config in this postccm-manager fallback-mgcp ccm-manager redundant-host "Call Manager Publisher"cc...
mgrimes by Beginner
  • 392 Views
  • 2 replies
Unity 5x license question
Does anyone know if Unity 5x has the same or similar type of demo license that 4x has?I have 4x in my lab that has always just used the license that came with the bundle (10 subscribers and 2 ports). This box is a Cisco MCS box we purchased for the ...
