Hi,Can someone points me to a good T.38 vs Cisco protocol for fax-relay ?Which am I suppose to choose ?Thanks!
Hello All,I'm new to VOIP technology.We are about to implement a SRST(2851 router) system at a remote site.The remote site is going to use 70 IP phones and 30 analog phones. We have two VG224 gateways to connect 30 analog phones.Does that VG224 supp...
Hi,i am wondering where i can put the caller name in the ATA. i can see were to put the E.164 (UID0/1)but not the caller idGood day
Are there any alternatives to using a ATA 186 on Call Manager 6.1? We want a device with the functionality of an ethernet analog terminal adaptor but do not like that we have to use a 10mb/half duplex port setting. I prefer not to have to use the vg2...
Hi,In our setup we are going to install CCM 4.3 with IPCCX 6.0.Once this environment is setup, after couple of months we need to do the ip migration and hence need to change the ip address of all servers.Can somebosy help to tell for the above setup:...
I have a DN which i have assigned to a unity server. I want to activate a call handler on that dn, but I am missing something because the unity server just plays opening greeting. how do I tie a call handler into a DN? thanks
HIThe IPMA and Attendant Console are support to CCME 4.x?Thanks
Hi all My 7960 phone doesnot take power from PoE switch, Pls tell me what is the problemThanksSudeesh
Hi ,System Verion :CCM 5.1.3System Architecture: 1 Pub 2 SubscriberFor accounting Purpose we need to give different Authorization Code to the users having international dialing access.As far as i know Authorization code for outgoing calls can be con...
Hi AllIm using CCM6 and trying to set up a billing server, im using a Windows FTP and Windows SFTP server. the problem is that the CCM is not sending any files to the FTP nor SFTP (freeFTPd).All my services are running.
Guys,I have a 2811 gateway with FXO ports in which I have plugged in a regular analog POTS line in one port. I am using Cisco UCM v6.1 on the backend for call processing.Since I have call waiting service from the Telco, I would like to configure it ...
Can I use Mobile Voice Access for the below.Calls from spain come in over the WAN. Then, we want to allow callers to dial-out to the PSTN here in the states. I got this working with normal inbound PRI calls.I tried to setup with first leg being voi...
Trying to setup the following.2 x Attendant Consoles with 2 lines each, servicing calls on a single pilot number.Distribution: First Available or Longest Idle or CircularAC Hunt Group members are configured as Username/Line (total 4 lines across two ...
Guys,just installing IPMA in Proxy mode and everything is worling great with the exception of call filtering. all other features are working great but filters are not working no matter what.for example, if i say id like to have an inclusive filter fo...
Customer does not have a NTP server and I need to change time for British Summer Time urgently. But when I try to change the hour in CUCM it changes the date! When I change it back it changes again! Anyone else seen this bug and has a fix?
Subject | Author | Posted |
01-16-2025 02:00 AM | ||
01-14-2025 10:33 PM | ||
01-08-2025 01:34 AM | ||
01-05-2025 12:44 AM | ||
01-03-2025 09:47 AM |
User | Count |
4 | |
3 | |
2 | |
1 | |
1 |
