IP Telephony and Phones
Labels
Dear sir i wanted to know that does CCME has a Capability to initiate/host at least four party conference calls by default? same with CCM ?I heard that CCM /CCME can only do three party conference.any doumentation and what would be the solution for f...
Resolved! Lab for BACD
Hi,i have set a lab with two routers:one have VIC2-2FXS (one of them connected to an analogue phone and another connected to the FXO on the second router)i can call from Router A to Router B IP phone, but i am trying the BACD with no success, ultimit...
twissam by Level 1
  • 9108 Views
  • 61 replies
Dear all,I add the following command on ccme but i can only made a conference call with three user at a time from my 7941 phone.telephony-service max-conferences 8 gain -6Any other config is required to make conference call with more than 3 users.Tha...
Hi,I am trying to configure a SIP account on my 2801 ISR Router using the CUBE functionality. I have tried all possible configuration combinations but it does not seem to register. The account works fine if I use a softphone such as X-Lite. My config...
I recently installed an Emergency Responder server. One issue I didn't realize is when I installed the Cisco OS, the windows NTP client didn't install. There are so many Cisco OS cd's, so I'm not sure which one to choose from that would have that c...
Specs indicate that the NM-CUE and NM-CUE-EC have the same 20GB hard drive. I was just wondering why is one 100 hours of storage and the other 300 hours of storage if both have the same hard drive capacity?If I wanted to upgrade my NM-CUE to provide ...
I have a user that just installed IP Communicator 2.12. It starts up okay but if he attempts to answer a call or place a call he gets a MS Visual C++ Runtime Library pop-up R6025 -pure virtual function call. What's this mean and how do I fix it?
k6lw by Level 4
  • 1718 Views
  • 1 replies
Just curious.Is it possible for a "lab" call manager (5.04) to use the production directory data (3.3.3 sr4) for the corporate directory access? If so how do I configure CCM 5 to do this. I just want to display the corporate directory, not perform an...
k6lw by Level 4
  • 287 Views
  • 2 replies
