IP Telephony and Phones
watch here Journey banner_2
Labels
Just a quick question, after just having rolled out our new CCM system, we are having a small call quality issue with the call dropping out then fading back in rather quickly. Just wondering if configuring autoqos on our L2 switches will help with t...
jkloza by Level 1
  • 592 Views
  • 2 replies
Has anyone been able to configure the C2821 gateway router to allow 911 callback through the PRI line successfully? 911 outbound call through the PRI is fine, but we need to be able to have the 911 operator be able to call us back if needed from the ...
Hieu Cao by Level 4
  • 339 Views
  • 1 replies
Hi all,I'm trying to send a call through a T1 PRI trunk from my 6608 --> CUCM --> router.What I'm trying to do is this for example:dial--> 1234 CUCM send to trunk --> routerusing this command:debug voip dialpeer all Currently I get no log of any mat...
fredj1234 by Level 1
  • 878 Views
  • 6 replies
Hello,We have CM 4.2 and an I3 server (SIP) for ACD and are having issues getting DTMF tones out our CMM blades to outside phones. When we dial them and the other end asks for an extension we are unable to enter any numbers from our phones. This only...
anthonymd by Level 1
  • 428 Views
  • 1 replies
I have a problem when receiving incoming call. The router strips the leftmost digit (0) off and present only the last 10 digits. for example when caller (0123465245) calls, only 123465245 appears on the cisco IP phone. Can somebody advice me on what ...
Tarek by Level 1
  • 598 Views
  • 3 replies
Hi,I have a 1700 running Version 12.2(8)YN, acting as a voice gateway with ISDN BRI lines.Everything works find, and it has been running for years without a problem.Now, when I try and divert calls from a Mobile to my ISDN DDI, I get the above error...
Resolved! IP Communicator
trying to install IP communicator for the first time and getting The error message 'Unable to initialize support for Cisco Emergency Responder'. the cluster we are registering to does not use CER but we dont want to roll this out as it will invoke a ...
