is it possible to send caller id out of a fxo port. I have a paging system connected from 2821 gateway via fxo. I can call paging system no problem but the paging system expects to see caller id of the Ip Phone
When users log into their âCisco Unified CallManager User Options Log Onâ site, they do not have the option anymore to download the user guide for the phone.Several users have requested to get this option back on the website. I have checked the e...
HiI read the Unity documentation and it indicates for Unity in standalone voice mail you can install the windows 2000 server, exchange 2000 and unity all on the one server. Then setup the server as voice mail server and message store on the same mach...
hello!i have a 2811 router,with CME and a freshly install AIM-CUE.my problem lies with the AIM-CUE.i do not have connectivity from my lan (phones) to the cisco unity.i can ping and reach the router,i can load cme gui...but i can not reach the cue.so ...
How can we see the call utilization/stats on the PRI gateway? show commands, external tool? Thanks
Hi all, has anybody already try to upgrade from cucm 6.0(1) to 6.1(1). The first node is not able to use 6.1(1) version indicating that there is no licence for this feature !!!! the second node is ok in 6.1(1).Any suggestions ?Thanks for your help.Ju...
We have a cisco 1760 gateway with 4 FXO ports connected to POTS lines. When a call comes into the POTS line, it's being plared to an IP phone on call manager. When the user picks up the call in call manager. You hear a second dial tone on the call an...
Hi,i am wondering if i can do better CDR on CME.currently i am using the following:logging to a syslog server. customer does not want local calls or the AA calls (those are all showing); can i fine tune it or use a third party you recommand.gw-accoun...
folks, Could someone tell me the difference between reset and restart in ccm 4.1. Also, do i have to reset the callmanager everytime i make a chance, like updating ccs, changing dn? any change required a reset on the specific device?
Hi,TAPS is configured and working.Is there a way to allow auto-registered IP phones to automatically dial the TAPS number when going off-hook ?Appreciate any advice.Kind regards,Neil
Hi there,having an issue with some of my installs and thought id get some insight. if i have a phone in say partition International , and then place that DN in local the call manager retains the international DN. so if i now do a search for DN it com...
HiSome of my users can login via CCMUSER web page but most cannot. They get an invalid userid or password response. I cant see any difference between the users that can and cannot login. Any ideas where I should start to look ?ThanksPat
hello,I am trying to upgrade CUCM from 4.1(3) to 6.0. When I install DMA 6.0(1)a to CUCM4.1(3), after installation I am not able to open CCMAdmin, DMAAdmin and any other pages. But when I uninstall the Informix Dynamic Server and DMA, the CCMAdmin an...
Does anybody know how h323 URI dialing works? Some of the video stations support this with H323v5. The format is e164@domain.com. I am wondering how this work with Cisco gk when the endstation use this method to join MCU via GK?
Does anyone knows if there is some was to rebuld a ccm 6 database ( i've to rebuild the publisher ) from a subscriber ?Many thanks in advanceLuigi
Subject | Author | Posted |
05-24-2025 08:05 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-22-2025 08:53 PM | ||
05-21-2025 06:23 AM |
User | Count |
5 | |
4 | |
2 | |
2 | |
1 |
