IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5726 Views
  • 14 replies
UC520 with FXO for POTS lines. 1 of the POTS line also services a single FAX Machine (Pretty standard for small business)QUESTION - how to configure UC520 to detect inbound FAX call and route to FXS port supporting the FAX machine?Our current Lucent...
bruce by Level 1
  • 562 Views
  • 4 replies
HelloI am facing problem while generating the CDR report.i am using Call manager 4.1(3).I am getting the message "30026:Data is available only from Dec 27,2007,to Dec 28,2007."Though i have enabled all the parameters related with CDR generation.
hi ,does any body know if we need to purchase or order license for presence server and mobility? i know for SIP phones we need device unit licese but does the presence server and extension mobility features come already with CCM5& 6???? im planning ...
Hey everyone --I have 3 customers so far running CM Business Edition, and they are all experiencing the same problem. After exactly 24 days the AC service stops functioning. The service itself is still started and seems to be working, but calls can...
ouhakheme by Level 3
  • 371 Views
  • 6 replies
CUE ver. 3.0.1I wrote my own scriptI want to set parameter MaxRetry = 0OrI want to change "Are You Still There" prompt to my language.CUE outputs followingse-10-1-10-1(config)# ccn application autoattendant aaModifying existing applicationse-10-1-10-...
rsefer by Level 1
  • 703 Views
  • 5 replies
