IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5539 Views
  • 14 replies
This is a theoretical question is for a college assignment. I'm just trying to see if the configuration for a contact center: a broadband FR access going to a router, going to 4 E1's, going to a PBX with ACD, going to a contact center has a bottlenec...
looking for information to help understand flex mode dsp. If I have local hardware conference between local & remote people (711 &729 codecs), does the flex mode provide transcoding, or do I also need to set up transcoding? thanks
hello i have call manager that is connected to PBX via BRI of 2811 gateway, the problem is when some calls between Cisco IP phone and the phone that is behind PBX does not pass, and it dipslays an error message.In attachment you will find trace of th...
dbenattou by Level 1
  • 264 Views
  • 1 replies
Hello all,I have a project starting tomorrow with linksys SPA922 sip phone and Call manager 5.x. I have started playing around with the setup but the phone's registration is rejected. Can you please point me to the right direction for documents that ...
jkofosu by Level 1
  • 330 Views
  • 1 replies
Hello,I am looking for an easy way to allow the end-user to configure a "Call Forward All" when the line concerned is not the 1st one. My client is using a Cisco IP Phone with 2 lines, he can use the "Call Forward All" softkey to configure the 1st li...
Hello, Apparantly, we cannot change the softkey template of a 7911G and CallManager 4.2.We would like to remove the “messages” button, as we do not have a voice-mail system.Any ideas why this does not work ? Did anyone tried this in the past ? (W...
dcharlier by Level 1
  • 410 Views
  • 2 replies
