i have a few users that already did the fast dial setup.Could you guys please let me know how do the users need to do in order to just dial the fast dial id and get the call routed properly
Does anyone know if there is documentation to change a H323 GW to MGCP? thanks
We continue to have random WAV files disappear.Ran DBWalker and found the following error,1218:(error) greeting is set to use a missing WAV file path:D:\CommServer\Stream Files\ConPlantMainAutoAttendant_Standard_MrGreeting_0ca980e3.wav How do we proa...
I KNOW HOW I CAN MAKE THE CONFIGURATION OF THE DID in case i have call manager connect to MGCP and in case i have call manager connect to H323 i need the configuration done on MGCP and H323 aand the call manager
Hi how can i tie a voice port to an ephone-dn with a trunk-group PSTN configured i mean i only have one Dial peer voice ?
We have one subscriber of the 4 sub in our cluster that has occasional high CPU and we go into Code Yellow. Started about a week ago. Happens about 10 times during the business day.All subs have about the same load with number of phones/gateways, s...
Hi all,Why my 7970G is displaying wrong time while all others are with the right time?I'm using ccme4.2, the load file on my 7970 is SCCP70.8-2-2SR2S, my ios is 12.4(11)XW2.I've set the time-zone parameter on telephone-service.This issue is driving m...
hi we have a centralised setup of ccm 4.2(3) and the ip phones are in different cities,we also have a trunk to USA also.i have blocked offnet to offnet calls for the external transfer to PSTN.But as the PSTN line is connected to the central site gat...
Hello there.Suddenly, for no apparent reason, no-one can CFwdALL! They can add a number (via IP Phone or CCM), and this displays on IP Phone. But if you call the DN, it just rings.Help!
Should progress_ind always be configured in dial-peers with h.323 gateways? If not, when should progress_ind {setup | connect | progress | alert} be used?Regards
hello, i have Cisco call manager connected to PBX via 2811 through VIC2-2BRI, the problem is sometimes the outgoing call does not pass and when i make trace, it displays what you will find in attachement.you will also find in attachement the confgiur...
dear sir, Anyone have installation document for the subject mentioned device? What's the feature we can implement on the device? Please advise. thanks.
I have a customer that uses extension mobility, they have 200 users with device profiles, they want to update the profiles with a soft key template change, i cannot find a solution to update the profiles. You can add, delete but there is no update op...
When pressing "Corporate Directory" buttonthe message "XML [4]: Parse Error" appeared.When using the previos version of IP Communicator 2.0.2 I have no problem withit and config of my CCM 4.1.3 wasn't changed since than.
Hi,I need to configure AAR in one of the UC labs. I have a question here regarding the Dial prefix. There are two dial prefixes.One from this group another to this group.I am not sure whats the use of Prefix(to this group).For example I have two site...
Subject | Author | Posted |
06-22-2025 11:50 AM | ||
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
