IP Telephony and Phones
Labels
Hi, could someone help, please.If CCM (ver.4.0) supports G.729 for the CTI-ports? The problem I have is CTI-ports can't dial to ip-phones after CCM is configured to use G.729. With G.711 everything is ok.Many thanks in advance.
AngryFriar by Beginner
  • 1012 Views
  • 12 replies
Hi,I'm trying to configure the PRI group setting on Controller E1 0/0 on 2600 12.2 to pri-group timeslots 1-31 and am getting the following message.%Voice interface must be shutdown before updating configuration.I tried issuing the shutdown command t...
johnnymac by Beginner
  • 1579 Views
  • 6 replies
Dear all,I've been struggling a long time to get my ATA's working. first I thought the ATA wouldn't work with HP faxes, but now... I even get communication errors on Canon faxes. I want to move all the faxes from my traditional telephone central, but...
WE have installed the Call Manager 4.1(3) and this is being integrated with a non CISCO (ITS Telecom VME Pro) Voice mail box.As suggested by Cisco, we hace connected the RS-232 Port and FXS Ports for communication.The incoming Calls are landing on th...
gsriraman by Beginner
  • 269 Views
  • 2 replies
I have a question about hunt groups and the way they work. First if I have the following hunt list with these ext.00010002000300040005Now I create a P of 8888. Now when someone calls 8888 and I have the option Top down. It will start calling 0001 and...
Can you experts please share your opinions on if Security is an absolute must in Cisco VoIP solutions? Specifically i'm talking about authentication between phones and gateways, and running Secure RTP accross the wire. The types of solutions I will ...
SBCdd7343 by Beginner
  • 232 Views
  • 1 replies
I am configuring E1 for PRI for the first time and am having some trouble. The telco has provided the following information;- E1 32 channels- Switch is primary clock- Framing is CCS- Coding is HDB3 and CRC on or off- Signaling protocol is SS7- Frami...
After enabling SRTP on our H.323 gateways, we can no longer dial a DID number for a specific user and get their voice mail. When using Call Viewer on the Unity server, you can see the call come into Unity just fine. All you hear is a busy signal.
I have a user in AD that is showing one message in their mailbox. When accessing from the TUI, they do not have any saved or new messages.I have tried to delete with Untiy Message Store Manager, but the item remains. Is there anyway to do this from...
Can someone point me in the right direction to troubleshoot a delay when users hit corporate directory on phone. It takes about 45 seconds to connect and allow users to do a directory search.Overall ultization is low from both a CPU perspective and ...
  • 285 Views
  • 3 replies
Hello all...have a problem that I was hoping someone could provide an answer for. We are a small medical facility with a switchboard that is occupied until about 8:00PM. At that time they forward incoming calls to the nurses station. Is there a w...
