IP Telephony and Phones
Labels
If an incoming call via an H323 Gateway is placed on hold after 10 mins or more conversation, the call is "lost", both sides getting white noise. If the call is placed on hold after 9:59 it's fine & can be put on hold again for up to 10 mins before t...
I have a customer that does not have enough switch ports and his budget is running tight. He was wondering if he can daisy chain the phones at least two phones to one port on the switch. He wanted me to find out if there "other customers" ran into ...
jgittins1 by Level 1
  • 1690 Views
  • 4 replies
Hello!Is there a way to authorize calls without forced authorization codes?I want to configure a phone to use a authorization code before making any calls(no matter where the call is being made - national, mobile, international).
CME failoverWhat would be the best way to implement failover in a standalone cme system.My thoughts so far are :Identical router minus the modules but with the same configIn the event of failure of the primary routerRemove modules and install in stan...
